unified component libraries
  • Thread starter Thread starter enrico1979
enrico1979
Hey, everybody.
I happened last week, for working reasons, to have to switch to use inventor.
I was able to test with my hand how I create it from another planet.
only neo, I hope linked to my knowledge at 360 degrees of creo:
bookcases with unified bolting, or even drawings of toothed wheels (for cylindrical and helical I created a family table that cmq made me feel ) that are easy to access with inventor are not available with creo parametric? .
I hope so (it is not tragic because they do without problems, but having already done them, with all the characteristics would be another thing).
thanks and good work
ciao, io ho trovato qualcosina qui with regard to the unified bolting, but of wheels not even half unfortunately. You should do a thorough search on the internet of some vendor and see if you have available them to create but I see it hard.
Bye-bye.
thanks for the information. I didn't look for a site that would allow to download the 3d models cad but I hoped there was an integrated module in the software that would allow direct access.
in this regard, as soon as you open pro and (or create parametric) there is the 3d model space site that allows you to access (for some voices you need the registration while for others not) to sections where to download 3d models such as dentate wheels - here attached ( View attachment Ruote Coniche.zip ) - (I don't know if you managed to do this, so I'll also place the link.
http://www.qtcgears.com/rfq/bevelgears.htm from which you can download (in any format) with conical and helical wheels )
hi and good work
ps let me know if the wheel file arrived
received, thanks for the wheel! in fact I believe that the browser integrated in I create is the most "direct" method to do this
