uniting face per training a solido
  • Thread starter Thread starter Alberto26
Alberto26
good evening boys, I need to merge surfaces to eventually create a solid.
I tried with faces - join, but still the result remains negative. How can I do that?
hi aberto.... join faces and the right solution however you have to accept that there are no double faces or open spaces and you have to take only the interested parties to the solid future....
Thank you, I've managed.
However, by making unified faces, he made me select all the solid and not faces at will.
is it possible because I have already made faces join before selecting all the solid (in my ignorance)?
One last question.
I used a loft to extrude a circle to another geometric shape because with extrudes I could not connect the two different geometric shapes.
Is it right the way I used it (loft), or is there a method even with extruding removes?
Thank you again.
One last question.
Thank you again.
Yes because by joining even if you are not solid it combines all the faces... then for the loft if you attach me a photo we see if I can help you
I practically have to extrude starting from the circle until I get to the species of high-key seat (or vice versa) and I couldn't do it with extruded removes but only with the new loft command.
I'll get you the file.
It's a drawing for a school practice.
hi tree the file gets damaged better if you send me a photo....
