Reynolds vs. Grashof
we must realize this shovel (present in attachment) for foundry. Since the tolerances obtained in the foundry are very bad while the internal surfaces of the spoon and knife are functional we would like to work with the machine tools, milling the knife vertically and polishing the shells. according to you is correct this passage or should we mill the spoons and then polish them? Since we cannot use cnc machinery according to you it is possible to mill or polish such a surface with standard machinery? we are open to suggestions that simplify the project as much as possible, remaining the need to realize the piece for foundry and then work it with machines not electronically controlled.
thanks to all
thanks to all
