teseo.guerra
hello to all I place a problem as from title.
I ask that I have decided to enter my doubts and my questions in the general directory on fem systems as such questions do not depend on the software used.
the text of this exercise is quoted:
"the plate represented in the figure (attached) is bolted at the lower hole and is loaded at the upper hole, by means of a vertical force facing down and at 5000n.
the thickness of the plate is determined, in order to guarantee a minimum safety coefficient of the structure pairs to 2, regarding the yielding, knowing that the material is a construction steel with yielding voltage of 350 mpa"and now put here below my questions:
1)The constraints to be inserted on my plate of course are located where there is the bolt now I would like to know according to you that this bolt prevents only the translations along the axis the x and the axis y or also the rotation around the axis z?(I assume that I will use a model 2d therefore already to be excluded are the long translations z and rotations around the axis x and y)
2)the method of analysis to find such thickness that I thought is as follows:I construct a model with a plate having a standard thickness of 1mm and determine my voltage for the calculation of the safety coefficient and according to the value obtained of this first safety coefficient (see how far from 2)I make a proportion of the type
first safety coefficient: unit thickness = safety coefficient sought:x (incognita).
I then carry out with the thickness value obtained a new fem analysis to verify my data obtained
in practice to obtain at least the order of the thickness then to blur a bit of numbers carried out before the analysis with unitary thickness and then as described above
