Unlock autodesk stick
  • Thread starter Thread starter beccamort
beccamort
is it possible to unlock an old self-desk key? the one I used for the installation of an old version.
I exempt this old discussion to report that the procedure (among other things very simple) reported in the link, works 100%, unlocked 3 32gb key each:biggrin::tongue:
I didn't understand a damn thing. I don't even know where to start. :mad:
It's very simple, don't worry. :wink:
first you have to follow the link put by giga, scrolling down, after the red “edit 10 – 2014 drives”, you have to click on the google docs link that you see below and you are sent back to another page. here, you go to "file -> download" so you download the zip file containing all those you see listed. once the zip file disappears inside a folder, you switch to the actual procedure
1) start the mpall_f1_0702_v363_00.exe file
2) insert the key (after a few seconds will be detected by the program by appearing the description in one of the gray boxes)
3) click on update
4) click on setting
5) select “advance setting”
6) select “load” go to the disappeared folder and select the mp.ini file
7) press “save” and then “ok” in the window that opens
8) close the window, returning to the previous one
9) press start and start the process. in the box where there were the characteristics of the key, will appear a blue bar with the written “do format” that then will become red with the written “is legaly falsh” wait a couple of minutes (probably already when the bar becomes red, you can extract the key but for security I preferred to leave it there)
10) extract and reinsert the key and the game is done, will appear the new unit “detachable disk” (checking the new drive, will ask how first the formatting)
If you have problems, ask me:
Thank you 1000!! I managed to format the 2012 key while 2014 failed, it gives me the error.
I didn't have the 2013 key, I downloaded it.
thanks a thousand after dozens of attempts in a few minutes solved and usb recycled and working.
Good morning.
our studio has 3 32gb self-desk flash drives, all of suites 2016 (2 product and 1 plant).
Can I get them back? I can't find anything on the net on this version. I have already tried the suggestions you write and many others, but nothing.
Thank you in advance.
