unselectable and non-changeable lines
  • Thread starter Thread starter jeanpier01
jeanpier01
Hello everyone
autocad 2010 is making me a strange joke; some lines don't select me at all: I try to select them in every way, but nothing happens; do not even respond to the various commands (cut, length, erase, etc.).
on the screen they appear to me, but it's like they didn't exist.
other lines, on the other hand, I make them select and edit (cut, length, delete, etc) but if they select it and want to move only an extreme (tipped on the square that appears at a flap), it does not move it.
the layers are all unlocked; I tried to regenerate it and make a purge, but nothing happens; The lines are all on plan z=0; I mean, it would seem that it's okay, but I keep doing this joke.
What could be?
Hello and thank you
I am currently finding it only on this file, also because I am working mainly with this file
open the block editor with modifbloc and save the block "double door".
You'll see everything is normal.
:biggrin: works :finger:
What happened?
Why did you make me this joke?
How did you know that?
You're a magician:
it was the only remaining block, after deleting all the other elements and doing a delete. the problem had to come from that.
But I still have a problem that I found before: when I go to calculate the area of a room, despite the snap square turns on, it does not take me some points (angoli);
I'll explain better.
-click an area size
- select the first point with the active snap
- select the second point with the snap
- select the third point with the active snap
- select the fourth point with the active snap but does not take it
only considers me the area of the first 3 points.
if I want to take the area of all 4 corners, arrived at the fourth corner, I will turn off the snap and click on a point appropriously near it
I noticed he's doing it on several rooms.
this from what can depend
put the file back with the only diffecting plants.
I circled you in red the points that do not detect
I don't know the fault at the moment. after I deepen better.
However if as a snap use the "apparent intersection"then the intersections detect it correctly.
ps: one of those points you indicated, instead, strangely to me with normal intersection correctly detects it.
