update blocks attributes
NiccoSub
Good morning.
I have blocks with attributes.
I would like to add an attribute to the existing block.
I create a new block, starting from the existing one, and I put an extra attribute.
the new blocks I put take them right. I don't update existing blocks. in the advanced attribute editor text window, I write the value I admit but comes in red and does not display it in the block.
Try to sync the attributes, redefine them.... I don't know how to.... :-)
?? but if the new attribute entered it in a new block (write: "I create a new block. .") why should it also appear in the old one?
Did you use the sincatt command correctly?
the labels you see them in red because they are duplicated, that is another attribute with that label. rename one of the two labels.
I create a block from scratch, put two extra attributes. except in the name of the existing block and I redefine it. the new block is ok. if I insert it new it asks me all the attributes. on the old (those previously inserted) does not give me possibility of correction
in the annex what you see fi and 21 is the "original" one
Thank you so much!! !
I can't tell you how you ended up creating a block with attributes labeled nothing ("").
However, the synchronization of attributes doesn't work... conflicts with the fact that the block is annotative.
Then do this:
1 start the block editor and place the annotative property on "no"
2 saves the block
3 uses sincatt for synchronization
4 again launches the block editor and reissues the annotative property on "yes"
Then do this:
2 saves the block
grazieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!! funzioni!!!!!!:-)
