cberto88
Good morning to all,
I have a large amount of drawings that I go to insert from time to time as xrif inside other files.
I had entered into the individual xrifs a data field with the file name, but when I attack the xrif on the target design no longer displays the name of the xrif but shows me the name of the file to which the same is attached.
I wanted to ask you if you knew a way to make the reference file name remain that of the xrif.
example:
xrif "pippo.dwg" - contains a text with data field file name and displays me "pippo.dwg"
when I attack pippo to the pluto design the data field updates me and displays "pluto.dwg".
I would like it to continue to display "pippo.dwg"
thanks in aticipo
example:
thanks in aticipo
