update projections
  • Thread starter Thread starter LuisIT
LuisIT
I use the command "project 3d elements" to place pockets, holes and other, but I know that if I move the element that generated the projection (in this case the center compass of a clamp for robot) does not update the position of the projection itself and the connected features. where is (surely mine) the error...?
thanks x every help.
question. when you project 3d elements into your sketch.. Are they yellow?
thanks for the intervention and nice question x that to 99.9% I think you have centered the problem. the fact is that as soon as I project them on the floor are yellow (which if I remember correctly are the projections), when I go out from the sketcher are white.
I forgot to premit that I'm cuffing on a catproduct projecting the profiles of a part on a sketch that stands on a surface of another part.
if they become white.. then make sure that the icon (enclosed image) is not set.. or should not be orange.
