update references between part
  • Thread starter Thread starter Dum
Dum
hi to everyone, I swear I tried to do a search on the forum but I found nothing that could serve me (in this case :wink: )
I tell you what my doubt is.
in a product of 2 parts, I carry out the holes on a piece and then the holes on the other piece posiziono through the concentricity on the holes present on the first piece.
If I move the holes on the first piece, the holes on the second piece should follow them and return to being concentric. . .
or at least so it works on other cad.
Why can't I do it on catia v5?
What am I wrong?
Thank you to anyone who wants to help me rise from the state of inniorance in which I am.
You're not doing anything wrong, it's just about setting up... I take my old answer here (some post below):
If you want to maintain the parameter connection, you need to change the system settings:
tools/options/infrastructure/part infrastructure/general/external references
check: retains the connection with the selected object
but I also recommend you:
check: confirms the creation of a link with the selected object (in this way choose whether to use the explicit or parametric reference).
You need to know what you do well, if you change one part without thinking how it interacts with the other, you can have problems.
Moreover if you delete the product or part, you will lose the links (see the embossed post "work in context").
recommending me again to be careful that with that always active setting not handled well, you may have more trouble than benefits.
years ago
Thank you so much for the answer! !
I thought it was soooled but strange that we could not automatically update the connection.
that a program that catches was lost in these nonsense was not possible.
I find it much less intuitive than other cads, but it is my problem, certainly not the program.
In this regard, I still allow myself to disturb you, because I think it is again a matter of sects.
I quote a sketch: if I first put all the odds and then I modify them, let me put them; if I put a quota and change the value immediately, for the next quota does not lose the command, it makes me select the item to quote, it displays it but at the moment I try to place the quota he does not put it to me.
I hope I explained.
What is it due to?
I must first quote everything and then edit or there is a "secret" setting:biggrin: .
good day to all and strength that is Friday!! !
:cool:
catia can work with a huge amount of details, so (wise) by default does not maintain links, otherwise the danger is that if anyone changes a part without making any case that is connected, this change will impact on all the related details, with often disastrous consequences. if the design team knows what it does, everything works well, if then the designer is just one even better.
for the problem of the sketch frankly I did not understand what you mean to "position the quota he does not put it to me":
you select geometry (or geometries with ctrl), then select the bond icon, he creates the bond, you place where you like, then with a click create.
you can also select the constraint icon and then select the geometry (or geometries) to bind, place the quota and with a click create.
double click on the quota
select the arrow or quota by holding the positions
Only sometimes it can happen that quotas because of the zoom are not temporarily visible, but change the magnification and see them.
Hello, thank you for your patience.
I understand the problem, but accustomed to having on other cad this option always active, risk instead of not updating the holes.
If I hadn't done a section on a pin yesterday, I wouldn't have noticed that I didn't update the holes on the second part and the workshop would have pulled me on the gums the wrong detail. :
for the other problem, I try to explain myself better, sorry but I quarreled with Italian as a child.. :
I "doubleclick" the bond icon.
I put a share and place it, put another share and position and go ahead.
at the end of the issue, I put the values that interest me.
It works.
If I put a quota and put it right away, the command remains to me, but if I try to place another quota he puts it on video but at the time when the posiziono disappears.
at that point I must again select the geometry and this time the quota makes me both see and place (and remains).
It's nonsense. I just wanted to know if it's a matter of taking the hand with a process other than the one I was used to, or there's an option to snitch the menu.
Thank you!
I tried to reproduce the conditions that originate the problem to you, but to me with the double click, the constraints are always put, whether they are published at the end if they immediately published them (and the bond icon is always "lighted").
I don't know. maximum try sending a screen of all the screen of the sketch environment, so that I control the icons.
Bye-bye. .
I did better. I made a mini video.. :
As I told you, doubleclick (the icon remains "lighted") modifies the first quota, the second makes me select the entity to quote, it displays it to me but when I try to place it disappears and obliges me to select the entity again.
Then she lets me put it.
This is more a matter of principle. :
Thank you and good week.
I see.
to me it does not happen and I believe not to others, so it could be some problem yours related to:
Setting? (I attach my sketch-related settings, the general and, solution mode + smartpick)
service pack? (I have the service pack 6)
video card? (I have a picture nvidia 600 with catia driver)
windows? (I have 7 professional)
I don't know.
We're in the same situation.
but I strongly doubt it is a video card defect.
I only do that if the command sequence is this.
That's not the end of the world.
I just wanted to make sure I didn't go crazy. :
Thank you for your patience. ;)
