all rights reserved
software, file formats, and audiovisual displays may be used pursuant to the
applicable software license agreement and contain confidential and proprietary
information of siemens product lifecycle management software inc.; which is
protected by copyright and trade secret law. such materials may not be reproduced
or transferred to other documents or used or disclosed to others for manufacturing
or for any other purpose except as specifically authorized within the terms of the
software license agreement, or as specifically authorized in writing by siemens
5800 granite parkway
suite 600
plano, tx. 75024
end of legal notices
this maintenance pack can be installed on top of versions:
100.00.00.133, 100.00.01.07, 100.00.02.07, 100.00.03.03, 100.00.04.04,
100.00.05.04, 100.00.06.03, 100.00.07.04, 100.00.08.03, 100.00.09.04,
100.00.10.05
note: maintenance packs are all inclusive and can be installed on top of the base
release or any released maintenance pack.
end of release notes
after downloading the maintenance pack to your machine, dbl click the downloaded
file and the maintenance pack will install.
end of installation
this maintenance pack addresses the following prs:
=====assembly=====
pr 1588004: ghost lines are visible in assembly
pr 1742690: user cannot locate keypoints when placing a circular pattern
pr 2110613: segments of xpresroute become disconnected in this file
pr 6135731: cannot locate part geometry for measurement in this file
pr 6183872: fixed a crashlog abort
pr 1724903: hole cannot be edited because of missing profile and extent type parent
pr 1685486: replacement of a family member causes relationships to fail
pr 1750159: crash when selecting parts within a group
pr 5949185: assembly cutout sketch and plane not moving as part is moved
pr 6126503: predefined archive entities were not getting copied into the active model session
=====part/profile/sheet metal=====
pr 1746654: cannot unfold in st
pr 1747721: problem saving sheet metal part as acis file
=====draft=====
pr 1741615: bogus error messages when removing item count from multiple balloons
pr 2130060: wrong angular dimensions
pr 6229940: solid edge draft aborts when using the trim command on background sheet
pr 6229622: printing (or saving as pdf) shaded views is not working correctly with st mp10
pr 1734926: incorrect text display in viewer data
pr 1741621: draft file is not saving when performing a special workflow
pr 6225522: not getting a title block when exporting to dxf on 64 bit machine
===api===
pr 2130405: trouble occurs when "addin" is registered in "quick access toolbar"
pr 6216674: moldtool command images incorrect
pr 2129831: in synchronousparts, "copysurface.type property" cannot be acquired
pr 2129884: implemented interpartconstructions and interpartconstruction automation methods
pr 6222930: automation on model node: cut length and component name
===insight/view & markup===
pr 1747128: insight managed files cannot be converted to synchronous
pr 6228351: multi-national clients can't sync to english server
=====embedded client=====
pr 1703717: having problems changing the separator for solid edge dataset names
pr 6221906: bom mismatch due to ordered list being incorrect
pr 6224180: error on draft check-in after ipa and check in of assembly from draft view
