urgent - cartiglio inventor
  • Thread starter Thread starter Yellowmode
Yellowmode
hi! I have a delivery tomorrow and I realized that my cartiglio is 20 mm while I have to set it 10mm will be a bullshit, but I don't know how to do it and at 7 I close the prints!!! :
another thing, how do I insert an inventor dwg autocad file?
hi, you have to go to the browser of the file, right-click on the type of cartiglio you have uploaded, edit definition, and then edit, from here you can also insert the dwh files
You're not very clear, too.
What is high 20mm, the text?
attach an image and write what you want to do.
Bye.
You're right. I'm in a pre-examination crisis.
cmq for the cartilage I solved, another problem I made 8 boards all in the same dwg file, in format a1.
the amount in autocad and the files are saved individually.
I open the files in autocad and ... 2 files are not in real scale!!! in the sense that he cares but with different quantities.. How come?
I open the files in autocad and ... 2 files are not in real scale!!! in the sense that I li import but with different sizes.. How come?
interpreter:
you made 8 boards in a1 format in one same idw file, when you expose to dwg of autocad you create 8 files ... it's normal!
two of these tables will be of details in scale other than the rest and it is normal (though unpleasant) that it does so.
the exported table still requires a minimum of attention to check that everything is as we would like.
I allow myself to add (I do not know if it has already been treated elsewhere, in the forum) that the conversion from idw (inventor) to dwg (autocad), however strange and inexplicable, does not always maintain the original size of the individual entities, indeed... :mad:
I think it can depend on rounding, however it is not pleasant (especially when you export drawings to be able to make verifications on plant layout. . . )
does not always maintain the original size even of the individual entities, indeed...
That sounds weird.
an account are the details climbed, but for all that is equal scale I never happened to see conversions with wrong odds.
