urgent! good catia v5
  • Thread starter Thread starter Lino.74
Lino.74
Good morning to all, I quickly expose my problem in hope that someone will help me.
I work at a metalmechanical sheet metalworking and assembly company where I have to make quite complex estimates. Unfortunately as software I have only a sheet (complete enough) of excel where I have to manually load all components and assembly operations. for each component I have to report information that passes me the research center that I have to transcribe on my sheet, in turn they do the bom "handed" and they put a lot of time to do it without counting the errors that make forgetting sometimes of the components present in the 3d.
I for verification use the glovius viewer that allows me to export a bom in pdf made quite well, with preview images, the list of components, maximum encumbrances and names of the components as they were appointed in the 3d na to me served in excel so that you can adapt my preventive module and make sure that you marry with the bom.
I come to the point: I ask you if there is a way (even with non dassault applications but you third-party companies) to extract a excel file with the bom and that reproduce the same levels with the axieme tree structure. I hope I've been clear.
thanks to all
There is this possibility.
you can export to excel or txt all the characteristics of catparts inserted in a catproduct.
material, size, treatments and how many more you want.
If you want your excel sheet to automatically update to catpart changes... in this case it is necessary to support a pdm
In the meantime, thank you for taking the urgency. I should have some specific example to make myself the idea of what he does, what do you recommend trying to get me an idea? Now I know feasibility, but I have to see, but I should come in alive. .
this is one of the many examples
can save the file in both txt and excel format
thanks victorious, I took a look, a file so composed (both .txt and .xls) is convenient to have the list of components and quantities (to simplify it, the list of expenditure) but I did not specify that I would need complete levels so that I have a distinct base that makes understand the ties with the assemblies. do you manage as a native catia or should you use macros?
but the upper part of the distinction makes a list of the composition of the axieme, I think.
while the one below... the shopping list .
Sorry for the absence, it is not that I am disinterested, the topic is now on standby and will be resumed later. In the meantime, thanks to all for the contribution.
