urgent please problemi with alias 13!!!
  • Thread starter Thread starter andreafly
andreafly
hello to everyone I am new and I know more where to bang your head...eheh!
I installed alias 13 on my pc (acer aspire 5745g sch. video geforce gt330m 1gb sist.op. 7).
when I activate the control points to change the cv all right, until I disable them. As soon as I do controls off my object disappears in all views and I only have a line that outlines the profile!!! to see it again I have to shader. the problem is also that I cannot select the object if not the line that remains to me. It is a little difficult to explain, think of a sphere, activates the control points, then disable them and disappears the 3d of the sphere and remains only a selectable arc.
I leave the attached file.
I'm freaking out is I need it because I have to make a quick prototyping at the weekend! !
thanks to everyone for any kind of help!
Andrea
alias allows the isoparametrics to disappear, leaving only the outer edges. what you see is "the outer edge" of the sphere, that is its double improper point.
How do you disable cvs? with a keyboard shortcut? verify that the same shortcut is not also associated with isoparametrics. or verify that you are actually switching off only cvs and not all controls, including isoparametrics.
I'm not familiar with alias 13, I stayed a little behind with the versions.. .
Thank you so much for the answer so hide...I dared a little but eventually I went to objects display , controls and try all the options and I managed to put all the isoparametrics back to the right place!
to disable the cv I use the menu' to watch. I simply crtl shift button dx mouse and click controls on and controls off, only that I deactivated everything including isoparametrics nn just the cv...!
Thank you very much
Andrea
I don't have alias under my hand right now, but I turn on and spend the shortcut cvs, which is a much more comfortable thing, at least for me that I do it very thick.
try to set it so from the shortcut settings, maybe you're even better
Okay, thank you. Just one thing. for shortcuts what you mean...
use alias but some things are still part of the "dark side" of the program for me...eheh.
Thanks again
Andrea
