use of licences, opinions.
  • Thread starter Thread starter windreef
windreef
Good evening.
It is not a specific discussion of inventor, even if it happened to me with that, so if I don't even know if it is the right section, but related to the new autodesk policy 2022 against piracy, all legitimate would miss us but in my opinion should review the ways.
it would be better not to consider customers of the scammers regardless, in order to pay (within 7 days) a new inventor license only because for 12 times in 6 months (the max allowed is 10) have remained active at the same time 2 licenses also for 1/2 hours (or a few minutes is not specified in the report) . in my case, for example, work at 100% fixed , I installed inventor also on the laptop (lecito you can install Max on 3 workstations property) than only use. It probably happened that by going to a client I forgot an active inventor on the fixed and so, rightly, I'm using two licenses for them. I do not context the controls but their solution, that is, after 6 months if you have connected at the same time to two pcs for more than 10 times (in my case 12) you get the mail that I tell you to pay a new license without possibility of defense from you. Besides, it is not indicated how long the two sessions are active at the same time.
I don't know, it seems like a little orthodox method to solve a problem, could at least send a notice after 5 connections saying, careful that at 10 we ask you money. I would be cool if I worked 12 days every six months.
40 minutes on the phone with the autodesk operator to convince her that I am not a crook (time taken away at work that allows me among other things to pay inventor)
I have said, do as netflix or others, to reach the users max connected, does not allow access. says they can't do it by law.... So amazon, sky, netflix are all out of law?
What do you think?
I didn't know this way... for how you tell, it looks like it's made to make strawfish... I think it becomes difficult for them to move on to legal level; They try and see how you react. Did you talk to your lawyer?
No, but the thing is resolved (after 40 minutes on the phone) , what upsets me is that it can happen again, I'm careful from now on, but I have to work not to think about these things. I told you clearly if your policy from this year is to look for someone to cheat, change software.
You can't work with anxiety when you go to a client: "Yeah, but did I unplug the license on the fixed?" put the hardware keys back then.... .
But if it happens to me again I really need the lawyer
but why do you have a fixed and a laptop and not the only laptop? It is also necessary to minimize the chances of falling into certain traps. . .
because I work better on the fixed, I already had the laptop and I installed inventor for convenience, which when I go to the customer if he wants a change and it is fast I do it immediately and I take the thought. However this is the third year I have inventor, and I have never had these problems, despite the use (and the possibility of such errors) was the same. they have changed politics since 2022, but they must immediately review the modes because so they lose their customers, they have to do as the streaming apps is simple.
Good evening.
What do you think?
so "by law" can not make evolutionary subscriptions with the multiuser (like netflix) however they can (always by law...their though) blackmail you to pay another full license because by mistake you activated the same license its two pcs?
Congratulations. . .
In fact, that's what doesn't come back and you can't keep this imaginary counter under my eye because you know which file it is. But what pissed me off is that they don't warn you by saying look at you using two licenses at the same time, stop right away. No, no, they're contacting you, you're wrong, you're paying and right away. dealing with clients from scammers so it seems a policy to the massacre.
If we think that even the viewers are now fired, this says it definitely long on how they are collecting money from all sides! and even viewers are subject to calls "or so or so." politics also married by ptc.
It's still all fair, but I think they're wrong, dealing with clients like scammers right away without asking for explanations that I don't find it right, but then 12 connections in six months really make a double use of a software? 12 days every six months can be considered work? Among other things, there were no full-day connections but of 1 or 2 hours which, as confirmed by the autodesk operator, after a few minutes of double use of the license, the system signals the infringement that is indistinctly considered " 1 day" . mah, perhaps the scammers are them.
Hello everyone,
I welcome this old debate, because I have received the same advice as windreef.
They even display over-use on three pcs, and I have programs installed only on two, office and laptop.
And nothing, I wanted to know how it ended.
You had to pay?
Hello everyone,
You had to pay?
absolutely not!!! . maybe because I pissed so much, disturbing all the saints (even the least known ones) that the chick was a bit shocked/unlucky and eventually yielded . but believe me that they are rompico...ni and start from the assumption that you are a crook, is what pissed me off. azz once the program buys it and I don't use craccati software, do you break my balls??? I'm out of my mind. I told him, even in the end, before giving you three thousand euros, I give them to the lawyer and see how it goes, then I move to solidworks and push all my clients to do the same. At the end he was convinced, but it took a couple of phone calls, because three days after the first peaceful call (which seemed resolved, but it didn't seem convinced me) another warning came to me, I raised the phone....and me.. from to rivers. However, I've tied it to my finger, the least chaplaint they make.
Hello everyone,
You had to pay?
However, now that I think about it, it's been available to autodesk access for a few months, which is used to manage double access, if you've already opened the software on another pc, you'll report it. I installed it at least no longer risk of having to fight
Three thousand euros?
to me they ask almost 18,000 for some blasting of a day yes and no per month.
and then I would like to see where the data comes from to say that I even have triple access, if I don't even have the third pc!
Anyway, I'll do my reasons, and I'll get pissed if necessary.
thanks to the answer and good weekend
3000 euros because it was 12 simultaneous accesses (in 6 months) from a second computer, which in fact was my laptop. and therefore demanded the purchase, for use 12 times in 6 months, of a second annual license as they considered a use greater than 10 times in 6 months as working use, ah ah ah . buffoons out of head... .
In your case there were also 3 licenses used, so the purchase of 2(beyond your) would be 6000 euros, I do not understand 18000 what account they have made. Unless they consider you to pay extra daily use, from this year there are daily usage vouchers, 12 euros per day, then 18000/12 = 1500 uses, considering on two licenses, it would be 750 days of use in practice more than two years, there is something wrong.
