I would say yes. Sure that if you have pumps with great inertia and to start them to regimen it takes 60 seconds it is good to understand that if they were started directly they would take great hits and above all they would suck a lot of current. for this, however, an evaluation of inertia at the start would not be bad.
when you control a pump, you have the inertia of the engine rotor and that of the pump. star screws with ramp and then over the first 5/8seconds you go to the triangle to stay with the load until you turn off. alternatives are the soft start or normal programmable inverter.
who designs oleodynamic plants is good that a conticino does it, especially if it has to provide the electrical part.
If you are a manufacturer and manufacturer of pumps, I would say that it is as good as given. then who uses them takes into account or not. normal application, formation from cellar = not needed. otherwise yes
