AC Design
to all the gentlemen of the cad rhino good morning and well found. . .
It's a little bit that I didn't write... while always following your threads... :smile:
I'm going to ask you a question...
as from attached images, I must report (the serious problem ) the polysuperfici that I have on the floor (ref. image "model axis y" ), on the fettuccia that will go to be, in fact, the base of the finished object (ref. image "superficie of reference" ), then to have this coupling (ref. image " coupling " ).
with the _flowalongsurface command, creating a surface using the curves of the fettuccia and bringing them back to plan y, the final result leaves much to be desired.
Would you have any other suggestions?
the trend of the object should stick as far as possible to the one on the y plan.
thanks in advance for any warm advice. :finger:
Good day,
alessandro casciani
ac design
Good day,
alessandro casciani
ac design
