mcdue
I leave the digression on why of my request that I have the poisoned tooth, I whisper it with the saying that I have a six-zero figure as annual repair costs of vacuum pumps.
to reduce these costs I would like to act parallel on two roads: sensitize to correct use the production and try to do predictive maintenance, but they are in crisis because in my course of studies I never had a way to deepen. So I ask you erudite forumists if you have material to turn on their operation, I accept everything, from scrap paper to high definition movies, whether in Italian or English does not make a difference.
then, if I also wanted to ask if you have advice or some company name specialized in systems for predictive maintenance of pumps for diathermic oil circulation, our idea is to measure temperature (pompane oil at 250°c) and vibrations, create a historian and then analyze the data and try to understand when the pump needs to be replaced and then go into repair to the mother house. We have no problem with bearings. . .
(if you need more details, just ask).
Two.
Two.
