*varia* separate materials weights
  • Thread starter Thread starter fabiogo
fabiogo
using the tubing module and frame generator happens that when I go to group (set rows) of the separate materials with the filter description, in the weight field appears the writing *varia*, I tried to change the options that I find in the column format field but without results.
Did someone find the same problem or know what might be the reason?
inventor joins the rows of parts having the same number part.
said that, you should have written the "hand" material (written blue). is it not by chance two equal details, but of different material, have different weight, so he joins them but writes "vary"?
I noticed the same thing, and I think that's the explanation.
for this reason, if I have to change something, I do it in the separate axieme: in this way it is reflected on the separate table automatically without generating errors. and if that axieme will be a subaxieme of many axiemi it will still be fine.
