Nickinge
hi to all, I am a graduate in mechanical engineering at the faculty of bologna, I just enrolled in this forum, and to tell the truth I do not know if I will find what I look for because from what I understood the forum is more focused on the mechanical design to the computer, but I still try to ask a hand:
I have a project concerning an over-charged marine diesel engine, and I'm making it using the gt-power program (what do you know? ).
I have already done all my calculations and have already made a model that satisfies me enough with its behavior to the higher rotation regimes, where the engine will work for much of its use. I introduced a turbocharger that I had to map by viewing the online catalogs of garret. Of course, I have the problem of turbo-lag at the lowest regimes, so I have to introduce a variable geometry turbocharger. I know already what type of operation must have at the low systems, because at the moment I have made two models of the same engine, but with 2 different turbos, one for operation at low speeds and one for operation at high speeds.
my doubt is this: how to map such a turbo? In the sense, mapping can be customized in any way by the designer or I have to expect to find something similar to the normal operating maps of a compressor with the return islands, rotation regime lines, axes with mass flow rates and compression ratio etc. Unfortunately I still know little about this type of compressors, they were not subject to study and online is found little, at least in Italian, at the moment I am checking if I find something in English.
would you also tell me a good online catalog where to find this type of engines?
Thank you for your attention!
