various parts and operation
  • Thread starter Thread starter GiuseppeAntorn
subject already dealt with. do a search come to pioli besides the forum also with google inserting the string cad3d.it arrived at pioli
@giuseppeantorn You probably broke google... I link you a bit of discussion though I think you're expecting the solution.
Good morning to all, I'm a mechanic student, I'd like to ask for help on a design of a pole joint. I should understand the operation of the various details, say how they are called etc., which are in the drawing. https://www.google.com/search?q=dis...aq&biw=360&bih=520&dpr=3#imgrc=dupal6z2zajfcmI have to find the individual components within the design. Thank you in advance. Have a good day.
as you see there are several posts where we talked about the pioli joint, how to size the various components and how to use them.
do you have any questions to which you did not find answer in the above mentioned posts?
the details that make up a pole joint, are the two joints and the pioli. Piles are steel pins with a rubber cylinder above which is deformed to have a curved surface. elastomer piles ensure the transmission of the torque, absorb shocks and vibrations.
clearly have functional and encumbrance limits compared to other types of joints.
then if you want to post the calculations, perplexity and drawings, we give a look and give you some advice.
