vault previous file versions
  • Thread starter Thread starter Lorenz578
Lorenz578
Good morning.
in the vault are present in history, all versions created of each single file.
I need to recover for example version 1 of a given file, but when I select it, this error appears to me and it does not charge me any of the previous versions.
how is it possible to solve and load pre-determined versions?
Good morning, the direct opening of previous versions does not work. you need to extract the vault file, delete the local copy and then download the desired version locally.
at this point you will have the obsolete file symbol but saving with inventor this will become more recent than the latest version of vault and you will be able to store.
Bye.
Forgive me, but I don't follow you.
I extract the file from the vault. The last version or the one I'm interested in recovering?
delete the local copy. clear from where?
download the desired version locally. How do you do that?
Sorry, maybe it's trivial operations for you, but I need to be guided more in detail.
