zetadierre
Good morning!
I'm working on a very wide vector, in which I identified project areas, which I highlighted with polylines that I assigned a filling. being only these areas the areas in which to do the surgery, I would like to create a temporary level that contains vector information only within them, so as to lighten the file. is there a command that, given certain areas defined by polyinees, maintaining the selection of them, allows to use that selection to erase items outside that selection, on a different level?
I've been a little twisted. to make me understand better, in mind ps, a reverse select and delete. But to define a selection with existing elements, in this case my regions. I attach a jpeg to make it clear what situation I am.
already we are.. how do I create with the parallel lines command a set of lines? in fact I can not create more than 1 than the second clik stops me the command... Can I give him a curved pattern?
