verification in reconstruction ctrl + q
  • Thread starter Thread starter dedoitalia
speedpack is useless, it is not exportable in dwg (necessary) it is not quotable at the table (necessary) you do nothing except an image. is one thing made in half that can not be used if not pre create figures.
regarding management.. I don't agree with what you say. if I open a set 10 times without touching and saving anything you should open 10 times in the same way and not with random errors.
I understand what you're referring to because when I started using swx I happened to make circular references or poorly stable models. an analysis of the model clarifies what the problem is and avoids it in the future.
all I've been taught in the various courses I put it into practice, but as I have already said once you exceed a number of components.... the stability shoulder.
I don't think it's a modeling technique, it's a cad limit in its management.
all cads sit at some point and from what I saw swx before sitting completely has these somewhat strange behaviors.
with speedpak you can quote in the harvests at the table.
Maybe you don't create speedpak properly and maybe you never deepened the topic.
export to dwg is a limitation that you know from the birth of speedpak, not because it is a bug.
sw instability, may be linked to the limitations of your hw when you start manipulating axioms of the size you talk about.
the hardware I use is very recent and high-end, two examples:
of the precision t5500 - cpu xeon 5560 - 12 gb ram - picture fx 4800 - disk sas 15.000 rpm.
assembled core i7 930 2,8 ghz - 12 gb ram - picture fx 5600 - disk ssd sata.
the fact that speedpack is not exportable in dwg is not a kiss, on this we agree, fact is that it makes it unusable at the moment when you have to replenish a dwg to a customer, which in my case as in many others is normal.
