lollone Guest Nov 18, 2009 #1 if in the construction of a feature on the sketch I create lines of construction, is it possible to display them in the table? Thank you.
Alex70 Guest Nov 19, 2009 #3 you can see if the reference lines are outside the sketch. these fall lines as curves, then in drawing manage its display in the various views with layers. Hi.
lollone Guest Nov 19, 2009 #4 Okay. I wanted to understand if it was possible to use also lines that I create as construction in the feauture sketch itself! I guess not so!
