view/hide everything
  • Thread starter Thread starter salvatore82
salvatore82
Hello I have a small problem seen the little practice with catia
apro for work a large porduct with many internal product ... now some catpart and catproduct of the logical tree are hidden...is there a command that allows you to visulate all the elements of the logical tree (axiemi, part imported and created ?) instead of having to select them to one by one from the logical tree and make right click displays
with the command view/hide you can do everything... Maybe you're not able to do the selection or to select everything or almost, of what is in the tree.
If that's your real question then know that the crate tree is not at all different from that of the window folders or similar.
then ctrl key or shift for multiple selections, or selection windows in the drawing area (also in that "no-show") .
there is also the possibility to set up through the catsettings of the keyboard controls to hide/view the selected body... I find it molt comfortable:wink:
I configured it with the espace bar. to better understand it is that wide moool button that is on the keyboard.
so by hiding and visualizing that it is a beauty:
