view it
  • Thread starter Thread starter albertot
albertot
hello to all: Does this display problem ever happen to you?
It's active. in the sense that if I roar the structure, that zone of "good" remains...as if it were a section.
it becomes quite complicated to work because you go to keep with the selections in that area...
I tried to save, restart, exit...nothing; with autocad just copy everything and paste into a new design, let's try here...
p.s.
If you're not
that is a classic visualization of the "clipping plane". I don't know in solid edge, but in many software (e.g. catia, alias, etc.) they set up a close and one far plane, and the display is only between these two floors.
typically the closest you put to 0 and the farther to infinite, but in some cases it can convent to use different values.
probably changed the setting, try looking for it. . .
window menu - new window.
the new one will be correct, then close the old one and you're good.
