gerryfi
I have realized, reading here and here and trying and retrying, a custom menu to insert blocks from me made.
the menu works almost perfectly for the objectives I had set up, image display block, insertion, popup opening for request data attributes, etc.
Since I work on plants in scale at times 1:100 or at turns 1:50 some blocks have to be inserted in different scale, but I can not show in the phase of insertion of the block, as it happens for attributes, even the scale ratio.
this is a command line for inserting a block
" [Luci012s]^c^c(setq cl (getvar "clayer") -layer _m 2dilluminazione; (setq at (getvar "attdia")) (setvar "attdia" 1) (setq at (getvar "attreq")) (setvar "attreq" 1) _-insert librerie/luci/luci012s \; \;^c^c(setvar "attdia" at) (setvar "attreq" at) (setvar "clayer" cl) "
mi potete aiutare ......
by gerry (fi)
by gerry (fi)
