Giovannino60 Guest Mar 17, 2011 #1 where is the property key in autocad 2010, that is where they are indicated and you can change the characteristics of the lines, written...... ?
roberto 2011 Guest Mar 17, 2011 #2 If you click on it, nothing appears to you? did you activate the fast properties? They also activate in the key I show you. Attachments propr-rapide.webp 11.6 KB · Views: 16
Giuseppe Mauro Guest Mar 17, 2011 #3 the dialogue also opens by pressing crtl+1, try to see if it goes. If it doesn't go (as happened to someone else a while ago), you probably need the service pack..
