view the value of the areas
  • Thread starter Thread starter fulviok
fulviok
Hello everyone
because I have to design shapes related to surface values.
I wanted to ask you if you can display the value of the area
of a retino or any other instrument in such a way that when the shape changes it gives me surface information.
Well, you need to figure out what you have to do exactly.
However on two feet the first thing that comes to mind and to use a label that displays the local area.es,aree, or you can create one for the object that you feel most suitable for what you have to do.
If you need to design a building based on the available volumetrics you can use the masses are there for that.
how can I have from the masses information about the value of the volumes I'm planning?
the concept is a little wide however to large lines you can:
to widen the problem drawing or importing a mass, apply it in the various views a label with the fields you need and precisely "size it" in the volumes to maintain.
once you do this you can use the mass floors to have information about the area the perimeter, the volume between one floor and the other, the outer surface between a floor and the sucessive.of course you can insert it all in an abacus for a more precise analysis.
to create a mass p. drawings before the corresponding levels, then select the mass and use the appropriate command.
Bye.
