maior
good year to all and good return
I have this problem
using vault I copied solid and tabled a welded structure
to make changes. Now I wanted to know: if I reverse the solid
the front view through the cubeview with the right in the drawing mix all the odds of the two front and right views.
I would like to be able to change the first that was right with the front and the front one with the right to not have to remake the table.
but in the "change view" command the orientation of the individual views is blocked
thanks to all colleagues
maior firenze
I have this problem
maior firenze
