views from section
  • Thread starter Thread starter Bryan
Bryan
Good morning, everyone!
We have a doubt about a procedure for putting pieces into the table, the question is: how do I make views regarding a already dissected view?
I explain, as an example attached, the view 1 is "full" the view 2 is "sectioned" but the view 3 which was created by clicking on the 2, is again "full", here I would like to make sure that the view 3 shows only what is in view 2 (that section) but in a different position, I hope I was quite understandable;).
thanks and good work to all.
you can trim the view; what you want to get at the end would be only half left of what you see now
then, it could work if I have the 3 standard views, but if I have to make an isometric unfortunately it does not work... or at least I don't know how to do... i.e. if you want to do the isometric view of the section a-a now by clicking "project view" click and I move to 45° but precisely it creates me a complete view, while I would like to put me in isometric only the sectioned part... you could do it?
then, it could work if I have the 3 standard views, but if I have to make it an isometric unfortunately it does not work.. .
in the specific request you want to get the consideration of view 3, which is not isometric.
You're right, I thought you could do both on standard and isometric views, but I was wrong. So in the meantime I solved using as suggested by you the rifila command for the 3 standard views, but precisely on that isometric could there be a solution?
Here we go.
great, finally following the explanations I used the right button method on the section and click on "isometric section view"! thank you very much!
