vincolare 2 quote
  • Thread starter Thread starter Shaba
Shaba
How do you bind two quotas?
In the image I would like the two scored odds to be half the 557 share automatically, without having to set them myself.
Can you do that?
Tnx! !
nothing, give an eye to the input interface (it looks like a calculator). you have to write the equation in this way
parameter controlled by equation=parameter reference/2
i.e. you have to write the result before the equal and the actual operation after. to insert the odds into the equation you have to view them and just click them with the open editor.
I did! Perfect.
attached to that arch there are 7 elements, wanting you could also parameterize their number?
This is more than a curiosity.
If you mean the number of segments I would say no, with equations controls numerical inputs such as quotas, the number of instances of a repetition, etc. not the number of lines you have drawn.
hi, can you connect the number of instances of a linear repetition to a cell of a excel data table?
Yes, you can change for each configuration both the number of repetitions and the distance, and this is for everything (or almost everything...?) what is commanded by numbers that appear to you double-click on its feature in the graphics area
with the open data table you place on the cell where variables are written and double-click in the graphics area on the distance quota or the number that indicates the number of repetitions.
