vista distesa
  • Thread starter Thread starter aerox
aerox
hello to all, I'm trying to put on the table an object with a view lying in a direction.
looking at the object I attach, I make a projection (which represents the direction of the view that interests me); Then I create a two-sided offset section, select a plane parallel to my screen, draw the three straights and confirm.
I would expect to have the option "full extension" in the section area option but I can only give whole destination or local.
the section that turns out is almost right if it wasn't that I just can't rotate it so as to make it parallel to the view, that I need to give the odds to es empio of the diameter of the real circle and not "accorciato".
Can you do that?
but is it possible to screen the section line that was used?if not, can you reconstruct it with sketch lines?
if I have two parallel lines, there is a way to insert a axis that stands in the middle between the two lines and to quote it with the real size?if for example I have a 1:2 scale and design axis between two lines, if I quoto the distance line axis is say 1:1 and not 1:2...
thank you very much for all your advice
Hello
Meanwhile, thank you for the answer. In fact what little I realized I learned from a thread that is located in the link you posted me.
in practice I can not unfold on the projection view if I use more than 2 lines for the section, obviously being three do not have a common axis to select when I use the whole ozpione (allined)
but is it possible to screen the section line that was used?if not, can you reconstruct it with sketch lines?if I have two parallel lines, there is a way to insert a axis that stands in the middle between the two lines and to quote it with the real size?if for example I have a 1:2 scale and design axis between two lines, if I quoto the distance line axis is say 1:1 and not 1:2...thank you very much for all your advice
Hello
in sketch environment when you create a 2d sketch if you go under change -> group -> associate at sight, all odds will be "right" even if you put on the table a particular climb 1:10 :wink:
Bye!
p-h
I can't open your file because I use wf3.
I did an example with a solid similar to that in the figure you attached.
thank you very much the same, thanks to your file I understood where I was wrong: when selecting the axis always gave me error (the lines have to intersect the axis), changing the visibility option edge pattern from total to area the game works (although ignore what it means. . )
I have seen that in your design you have both a sketch of cartilage and the section line on the view in the plant, especially for this which flag you have to activate to have this line?? ? Thank you very much because I went into depression! ! !
right-click the section,selections display arrows and tell them which view to place them.
otherwise on view properties with section, on the section option there is display section arrows.
okappa, thank you very much! solve also this grain!:-)
ps. on the section speech does not return something to me, it seems right but the display style is stuck on wireframe and other pieces that you should see (but are not intersected by the sections lines) are not displayed. . What advice?
But today I came a doubt, I reviewed the design that you sent me and visible edge is on total, then I created another projection, I used your whole sez 2d (aligned) and when I go to select the only axis that there is always tells me "all lines in the cross section must intersect the axis.choose another axis"...where wrong?
years ago
years ago
I authorise that maybe it can be useful to someone: imposed the section, I tell him whole aligned, then put visibility edge on area, I choose the axis, then change the visibility from area to total and finally apply. with this procedure works.. .I don't know why if I leave the setting doesn't catch the axis...maybe it can be a beak of the program (ver 4 m050) or maybe it's me who can't use it well!;-)
Hello
