vista esplosa
  • Thread starter Thread starter Utente NX
Utente NX
Is it possible to insert an explosive view into a table not of that object?
example :
exploded view of a motor (generated with a new view and the tools of the explosive views)
this 3d view I want to insert it as view 2 in exploded state into a specification of another object.
in a few words in a table a0 (specification) which is the exploded booklet of the machine, I want to put the explosive views of the individual sub-assiems.
so in a table that is the code of the book exchanges there are all the explosive views of the sub-groups.
I hope it was clear.
I ask this because I created the engine explosion and saved the view in exploded state, but when this code I put it on the table, in the list of views I see my saved one, but not in exploded state.
example :
the procedure is:
- upload the assembly
- create assembly table with master model structure
- in the 3d of the table make a save as of the view (e.g. espl1)
- create the state of explosion (exp001)
- eventually save the view in the desired orientation
- go to the table.
... you will see that when you add the base view there will be espl1
the procedure is:
- go to the table.
Thanks matrix, but I meant something else.
I would like to put on the table the explosive of the aid at the board table b.
Can you do that?
If you can't do it.... I'll come with other less spicy methods anyway.
Can you do that?
I think the first submenu of the add-base view command is "part".
If you select the axieme from the drawing of the axieme b does not show you the view exploded?
I see the name of the view, but it doesn't put it in exploded state.
from what I could verify, the view exploded, is seen only if you do the design in the part (not master model approach), or if you do the exploded in the specification of the assieme (master model approach).
I did a mini-test... You're right. .
You better open a pr to the hotline.
you only have work-arounds... Sorry.
