visual replace is gone, what do you do?
  • Thread starter Thread starter stefanobruno
stefanobruno
Good morning to all,
I open a new discussion instead of hooking up to my 3 years ago.
the question is more serious, the app is no longer available ( fortunately I have a copy kept in safe ).
said that, do you use anything else to satisfy this serious loss?
I don't know that app and what it does prove to describe the operation, maybe something
select an element present in the axieme and the app asks with which element, always present in the axieme, to replace it.
if the items to be replaced are more than one, you can choose between one or all. (this part does not always work well, but it is not an influential thing for me )
excuse the banality but what difference does the inventor substitute ask you the same if one or all?
I don't have to go to select a missing file in the dir of the pc, but I see the piece by which to replace the other.
buongiorno,
utilizzo questo ilogic:
ooccurrence_old = thisapplication.commandmanager.pick(selectionfilterenum.kassemblyoccurrencefilter, "seleziona il componente da sostituire:")
dim doc_old as document
dim curfilename_old as string
'get the selected item document occurrence name
doc_old = ooccurrence_old.definition.document
'get the path and file name of the selected item
curfilename_old = doc_old.fullfilename
ooccurrence_new = thisapplication.commandmanager.pick(selectionfilterenum.kassemblyoccurrencefilter, "seleziona il componente sostituto:")
dim doc_new as document
dim curfilename_new as string
doc_new = ooccurrence_new.definition.document
curfilename_new = doc_new.fullfilename
sub_tutto = inputradiobox("sostituisco tutto?", "si", "no", sub_tutto, title := "")
if sub_tutto = true then
'false is replace , true is replace all
component.replace(ooccurrence_old.name, curfilename_new, true)
else
component.replace(ooccurrence_old.name, curfilename_new, false)
end if
