visual representations?
  • Thread starter Thread starter giuglioconiglio
giuglioconiglio
hello to all, in creoelements 5.0 I would need to represent a subaxieme in two different positions to verify various encumbrances. Is this possible? How? I looked at the simplified raps but it seems that there you can only turn off components. Am I right? Thank you for your help. m.
the simplest system is to use 2 or more strings, depending on the positions, which you can turn on or off at your liking.
or you can use a movement connection that allows you to move the subassioeme where you need it.
with simplified representations, reassemble the components you want to see in another location again, then turn them off in the default and do the opposite in the representation you want to show as second position.
