visualization of patterns
  • Thread starter Thread starter MarcoMasotti
MarcoMasotti
good morning, in the modeling phase I noticed that every time I select a sketch present in the feature tree also appear the quotas defined in the stage of realization of sketch. at each quota is associated a tag of the type d1@sketch... what I would need is that when I select the sketch do not appear the size of the quotas but these tags d1, d2... I tried to search between the options but I couldn't find the option that allows me to do this... can you suggest how I can do it?
go to instruments/options/general and put the flag on "show quota names".
double-click on the features or sketch you will see the value and in brackets the tag: 100 (d1) 12(d2) etc. with the enabled option the tag also see it for the features odds.
I don't know what you need to view the tags that swx sets the defaults, but be careful because the first quota you put in the sketch will have the tag d1, the first share of the function for example extrusion will have tag d1, the value that corresponds to the number of repetitions of a feature will have tag d1, the angle in degrees of the first feature of revolution will have tag d1 etc....
If you want to have really unique names in the property manager, type your text in the "primary value" field.
I don't think it's possible to remove the numerical value of the quota from the display and leave only the tag (and it wouldn't even make much sense).
you can also delete the numerical value in toto, just delete from the text of the quota the written "<dim>"</dim>
