hmm is not enough to save a volume analysis (or add it as an analysis feature) and add a "floating" note that shows the value of the parameter associated with the volume itself? I have to try. .Hey, maybe the question is stupid. but how do I insert a note on the model tree or screen of the volume of a solid that updates to each modification. as for the area.
I managed to add a volume analysis feature but I would like to see it on screen and not in the model tree.hmm is not enough to save a volume analysis (or add it as an analysis feature) and add a "floating" note that shows the value of the parameter associated with the volume itself? I have to try. .
Palo
You mean in window 3d? add a note type datum annotation (scusa ho pro|e in English, I hope it is easily applicable to Italian), or even directly a note annotation, and in the text of the note put &vol:fid_12312 where vol is the name of the volume parameter associated with the feature analysis and 12312 (numbers randomly placed in my example) is the id of the feature analysisI managed to add a volume analysis feature but I would like to see it on screen and not in the model tree.
Is that possible?
I followed your procedure but I can't display the volumeYou mean in window 3d? add a note type datum annotation (scusa ho pro|e in English, I hope it is easily applicable to Italian), or even directly a note annotation, and in the text of the note put &vol:fid_12312 where vol is the name of the volume parameter associated with the feature analysis and 12312 (numbers randomly placed in my example) is the id of the feature analysis
Palo
Strange, I tried yesterday and it worked, isn't that you have "hidden" notes in the settings? What do you use? I could send you the part but it's wf 5.0...I followed your procedure but I can't display the volume
