volume value without exponent
  • Thread starter Thread starter and
and
saves you can calculate the volume (in dm3) in a number without exponent
This is my ilogic code:
syntaxeditor code snippetiproperties.value("custom", "volume") = math.round(iproperties.volume / 1000000), 5).tostring
result: 1e-05!!
real is 0.012378
real is before calculation if I look at it in the physical property tab. .
I divide it for 1000000 to turn it into dm3
ok, but if you divide 0.012378/1000000 becomes 0.000000012378 then holding 5 decimals = 0
no the initial value is in mm3 and 12,378 and to convert it to dm3 I must divide it by 1000000
then it becomes 0.00012378 that pero inventor me displays it as 1e-05
from 0.012378 have we passed to 12,378 as real value to divide?
also excel displays exponential values (1e-05) but you have not yet mentioned where you view it or where you want to view it. . .this value in cm3
here are the values where I see them
in the custom tab and I made it compute with the ilogic:
syntaxeditor code snippetiproperties.value("custom", "volume_dm3") = math.round(iproperties.volume / 1000000), 5).tostring
Okay, but it gives you a syntax error.
"tostring" is a function that returns a string but must be written "tostring()".
try to use "cstr(math.round(iproperties.volume / 1000000), 5)" for string conversion.
even with your function always returns me = 1e-5!!
Okay, I'm sorry, but in a hurry, I neglected an important detail.
Code:
iproperties.value("custom", "volume_dm3") = math.round(iproperties.volume / 1000000, 5).tostring("0.#####")
