warburg
hello to all, despite the August that looms I would also ask here some information about the use of vectorworks. I am using the demo of the 2009 version and in particular I am trying to understand the modeling functions.
the first thing that has bothered me is that to extrude a polygon you have to go to the menus, choose extrudes etc etc, which for me old autocad user is particularly incomprehensible. . In the same way it happens for the views, to change and move from one to another (typically from the plant to the asonometry and vice versa) you have to make the tray of the menus, when in the autocad environment just an icon.
I do not claim to find the same procedures that I already know in a new program, I just want to understand if someone can explain to me why it is better in this way!
autocad in modeling has always seemed to me "a wood", especially after trying google sketchup or bonzai3d, which have some brilliant and direct functions in the construction of solids and in their modification.
I'll add one last thing. Coming from autocad the typical work I will have to do to model is to import 2d designs in vw and then use them as a basis to extrude in the new environment. the best procedure according to you is to make polygons closed the different "pieces" and then extrude, or is there a sketchup type way to make more quickly recognize the areas to the program?
Thank you very much
and good holidays to those who make them
Christian Christian
Thank you very much
Christian Christian
