wall layers line thicknesses
archfloris
Good morning!
how do you do in revit 2013 to change the thickness of the lines in the various layers of the masonry?
My purpose is to mark the line of the wall to the rustic, so excluding plaster.
the guide indicates how to select line strokes and change the thickness, but I would like to assign it in all view, so that it is easily editable even later.
I tried to change from the properties of the wall the line of edge of the brick, but having a taped masonry, I marked all the faces of the two layers of brick, while I want to mark only the outer line of the wall excluded the plaster (then for the outer brick only the outer line, for the inner brick only the inner line).
Can anyone help me?
Thank you!
that I know you cannot change the thickness of the line of a layer of the wall. in the object styles window (or visibility/graphic) you can change the pen used for common edges, then of all layers
esimio colleague:wink: ... allow me to contradict you. open the window "visibility/graphic settings" you will find on the bottom right the flag "stile cut line" in the section "replace host layers". check the flag and click on change. there you can assign different colors, styles and thicknesses per function
Thank you! doing so goes much better but I still have a problem: I change the thickness of the whole layer of brick (even the face that quards the inside of the wall) while I would only like to big the line between the brick and plaster, only on one side.
Can you do that?
In a nutshell, can a layer of brick never have a big line on one face and fine line on the other face?
