walls and pillars visible on all floors
  • Thread starter Thread starter Bubuiuiu
Bubuiuiu
hello to all...an information I have a 3 floor building, I made walls on the basement floor but when I go to the other floors these walls do not see... how come?? How can I solve this problem? ?
hello and thank you in advance.
Hi, I just signed up and took the opportunity to try and answer.
If the walls you designed have the height of the floor you are working on, there is no way to show them on the other floors. because archicad recognizes that they belong to the basement on which you drew them.
if you increase the height of the walls, which then go to height beyond the limit of the floor (established in the flat settings) then will be visible also in the other "relative" planes, in the sense that if the wall rises and is visible both on the ground floor and on the first floor, you will continue to see them passing from one floor to another.
but if the height of the walls increases, the whole part of the qto... would you like to tell me that archicad does not have the possibility to show the walls below or above? convenient...
Dear Tristan, Paolo said what I was about to write to you.
if you need to have as reference the walls that are located downstairs, activate the plan where you need to draw with a doubleclick. at that point right-click on the plane that interests you in the browser and select the item "show as a reference sublucent".
to make;)
