walls associated with plant views
  • Thread starter Thread starter 00zylit
00zylit
I have a problem I can't solve.
I started a new project with revit erasing and editing a previous one. I now find myself a model almost finished and I have to change the heights of the views plants, only that when I go to move the view logically moves me all the objects that were created from that view (extrusions on path). how can I do to remove constraints and move only the view?
...I had to change the heights of the view plants, only that when I go to move the view logically moves all the objects that were created by that view (extrusions on path). how can I do to remove constraints and move only the view?
:confused:
Move a view? Isn't it clear what you have to do?
I'll explain. until now I had set the plant view of the first floor at 3.30m height. when I did the various extrusions on the path I used as a reference view to draw the path the view "first floor" now that I have to mount the loft of the first floor I want to lower the view "first floor" to 3.20m. consequently if I lower the view they lower all the extrusions I have done.
I hope I've been clear.
What did you need these extrusions on the path? couldn't you avoid in-place modeling?
it was impossible to do so without using the route extrusions. Anyway, I have to try and solve the problem now. I couldn't start the project again anyway.
Let's say, to stay on the vague, that if you put extrusions at that point a reason and a relationship with the rest there should be. If you lower the level of the first floor it is also right that these extrusions follow the trend. generically speaking. but if you place an image you should better understand the problem.
I'm solving by changing the extrusion paths. However if someone knew a faster method.
insert a new plan (view) to the desired quota.
selecting by category, all objects (excluding those of place modeling) that you need to change, reconnect them to the new "first floor".
