warning in configuration file line
jim78b
ciao ho me10 v17 mi dice il server questo:
warning in configuration file line 5381: password has expired at 2018/8/13-05:50:23
cosa posso fare?
cosa posso fare?
If you had a permanent license, you should call your dealer to cover the matter.
I know in time since in the .conf file there is '2020 and not beyond .cmq tells me password expired and not licensed
cosa posso fare?
the thing a little abnormal is that the password is no longer valid since 2018, besides modeling also version 17 warned you a month before the license was about to expire and you appeared the message at every software startup and I think it should be the same thing for drafting (i.e. me10), I would not want that what doesn't work to you is a simple application, maybe the software house that followed you and removing that application anyway.
However any software house, active in lombardia I know at least two of them, you call you "rottama" the old license, if it was permanent and sells you a new one, which unfortunately is annual.
Can it be like you say that software house is x favor?
one is the cdm that has historical headquarters in the province of parma but also has offices in milan and in other cities of the lombardia but is a little exasuous, the other sincerely I do not remember the name but it is definitely located in milan.
if you need to take the "base" version I recommend the cheapest software house, if you need a pdm or additional modules, any type of customization etc, it is better the cdm, especially if you need to make complex plant designs and design a 3d layout in a short time, have a specific module, which is called creo factory design, designed specifically for 3d layouts
the sit srl engineering solutions has physical locations in brescia and ferno (va)
thanks you were very kind . the computer qs has an additional module that transforms autocad like me10 but costs a lot of rent for a private like me :(
