lory.b
the nna made available vw2010.
you can find all the information on the sitehttp://www.nemetschek.net/
lo
lo
I think I can guess, but not entirely."with the release vectorworks 2010, nemetschek north america has further expanded collaboration with siemens plm software, thanks to the integration in the d-cubedTM system software – 2d dimensional constraint manager (2d dcm).
Dr. biplab sarkar, chief technology officer of nemetschek north america said: “We chose to integrate in vectorworks 2010 the 2d dcm system because siemens has the solution that many believe to be the most sophisticated in the field of parametric constraints management. we have also been able to integrate it in the 2010 version so that it is non-intrusive for users and is really intuitive to use. ”
the parametric constraints, however already present almendo from the 2008 version and probably now improved.http://download2cf.nemetschek.net/www_movies/2010/dcm_integration_final.movwarburg said:I would like to ask you what exactly is meant by:
the "motor" 3d of vw was changed. since 2009 they adopted the parasolid kernel of siemens plm. this has made solid modeling much more fluid and consistent.we talk about the contribution that siemens plm software would give to the solid modeling, with the full application of the potential of the parasolid kernel etc... I would like to ask you what exactly is meant by:
no, that is the "interactive size editing" I overwhelm the membership fees, improved in the fact that now editing the quoted item the following, as you rightly said. but the membership fees also in this case have always been, at least since 2008."dimensional constraint managers" means a new system of membership quotation. to make an example, quoting walls. moving them and/or resize the quotas follow them, without getting rid of them and indicating the new values. At the same time, I can edit the quota by inserting a new value and the associated object resizes
the 2d-dcm also manages the relationships and constraints between the various entities of the sketch and together with the other modules of the d-cubed http://www.plm.automation.siemens.com/en_us/products/open/d-cubed/animations/index.shtmlare practically all implemented in the most popular mcad3d for almost twenty years."dimensional constraint managers" means a new system of membership quotation.
