gfrank
wbs: Structure construction work with softwarethe use of the wbs allows to improve communication between the different actors and to better understand everything that happens during the process of execution of the works.
each activity is devoid of ambiguity, as it is described in a clear and complete way.
each task is entrusted to the responsibility of a single person and there is no risk of duplication being created in the activities carried out.
Moreover, the use of the wbs allows to disassemble all the activities of yard in detail, making them understandable also to the subjects not involved in the execution of the work.
wbs and work newspaperalso the work newspaper can be structured by a wbs.
once created the hierarchical structure of the wbs it is possible, by the actors involved, to associate Notes e Resources at every level of the wbs.
association annotations at the levels of wbs 1
association annotations at the levels of wbs 2
association annotations at the levels of wbs 3
association annotations at the levels of wbs 4
In the example in question, once the wbs were created, the actor involved in the execution of the works, can insert a annotation by associating it to a level of the wbs (an annotation was inserted on the 12th day under the heading “hand excavation”).
wbs and computationalso the metric compute can be decomposed by a wbs. to this end it can be useful, at a preliminary stage, to define a structure (diagram or template) that has the function of simplifying and dismantling all tasks in detailed activity.
the construction of a wbs is expected in those cases where you already have a clear idea of the goal to achieve.
the wbs applied to a metric compute allows to improve the understanding of a project as it simplifies, already in a preliminary phase to computation, all the procedures and activities to be carried out described clearly and concisely and without any ambiguity.
e.g.: create a wbs and associate its articles of compute at the respective hierarchical levels of the structure.
creation wbs
association compute voices at the levels of wbs 1
association compute voices at the levels of wbs 2
(bottom: acca biblus-net)
