TEKNAMBUL
good dayI all wanted to know if in the distinct solidworks materials it was possible to insert the weights automatically
Thank you in advance
it does it already normally with the default installation, using the default table.good dayI all wanted to know if in the distinct solidworks materials it was possible to insert the weights automatically
If you don't have the weight column, just add it. It's one of the properties you can add.I have created the axieme and now I have to put it on the table and generate its table materials but when I genero the weights of the individual pieces do not come out you can add
If they don't come out, or you didn't give the material or you forgot something else. you have to give us more information:I have created the axieme and now I have to put it on the table and generate its table materials but when I genero the weights of the individual pieces do not come out you can add
Hello I wanted to continue this discussion, I have the same problem as tek,If they don't come out, or you didn't give the material or you forgot something else. you have to give us more information:
- in model 3d part or together in properties are there values?
- Are the fields correct in the table?
Is he just doing it with that file or always?
I did a test, in the property of the part I added only the material; adhered to in the table comes out the weight but cmq I can not see the material.but are you sure that in the default bom-all there are all the correct fields and especially equal to those of the property of the part or together? ?
if you call the same variable works...as everything else. at the limit you have to check in the options the item updates mass properties to the rescue (although this should be to update changes and for itself the weight should give it, even not updated).
I finally opened my eyes and arrived!!grz 1000 of the support!:finger:the table format you as you want, with the fields you want and with the custom or specific properties of the configuration. then save the distinct model and next time use that again...and not the default sw.
everything has to work
