nunzio1981
Good evening to all,
I find myself listing a welded assembly (with nx10 but this is not the problem), frame, frame or support and consisting of countless welded parts. I can't attach the design for industrial reasons. I'm pointing out the geometry. is essentially with longitudinal section in the shape of "7" with two triangular plates welded transversally. on a triangular plate is welded a handkerchief according to two different angles oriented than the triangular plate. on this handkerchief there are 4 holes.
other side.... history stax but on the handkerchief I have 2 welded dowels whose upper face is oriented according to two corners of verses.
on each dowel there are 4 holes.
Now I have to share apart the whole but also the position of the holes compared to a reference placed on the inclined part of the "7".
question: how do I come out?
someone has a design, advice... etc.?
desperately thank you
