Kaji
hi working in hygienic design environment I was suggested using "prisoners to weld"; doing an internet search I found that for prisoners to weld in reality they mean these threaded pins to weld, I asked if you also had experience in their use and especially that small male indicated in figure with diameter d2 and length l to what it serves?
to slightly lift the pin with that inclination of 3° to facilitate the welding and especially the use is recommended mainly on bearing structures such as tubular etc or even on simple sheets of thickness 2 or 3 mm?
thanks for any answers and advice
